[ANSYS Meshing] [Workbench] How can I get the element area data?
Old   June 17, 2013, 09:52
Default [Workbench] How can I get the element area data?
Novosiberian is on a distinguished road
I solved a mechanical problem and now I'm interested in the strain energy analysis. Typical solution in the Workbench gives you the strain energy volume at the nodes of each element (these colorful images in solution of the Mechanical Workbench). For further analysis I need the calculated strain energy at the nodes AND the corresponding area of the element (in my case the simulation is 2D, it would be the volume in 3D simulation). In statistics of the meshing I just have the amount of nodes and elements, but not the exact data for every node and element.
Does anybody know how to extract the data from the ANSYS Mechanical? I've been searching for the whole day and now I'm thinking that I have to write an additional script for this... It would be really time consuming for me, since I am not really familiar with IronPython.
Best regards and thanks in advance!
Novosiberian is offline   Reply With Quote
[OpenFOAM] Paraview: Cell data and Point Data? vitor ParaView 4 May 15, 2015 17:56
interpolation method on unstructured meshes harry Main CFD Forum 9 October 3, 2006 01:10
Saving particle (DPM) data to file? Philip FLUENT 2 June 12, 2006 01:41
write data points of a defined area in a dat-file Gernot FLUENT 0 February 15, 2006 09:23
Simulated data vs. experimental data moiami FLUENT 0 December 19, 2002 01:03
