[ICEM] set workbench parameter in icem cfd script
Old   April 24, 2013, 18:57
Default set workbench parameter in icem cfd script
nnvoro is on a distinguished road
I need to set the Max element in Global Mesh setup as a workbench parameter. Normally while working in ICEM CDF through workbench it is possible just to click in a small window near Element size to set it as workbench parameter. As I'm working in ICEM calling it interactively through ANSYS Meshing I don't have this option.
Does anybody knows what command should I add to script for ICEM CFD to set workbench parameter?
nnvoro is offline   Reply With Quote
Old   April 26, 2013, 03:39
Matthias Voß
mvoss is on a distinguished road
hey,
i resolved this problem by creating an User Input Parameter for the ICEM container. Overwrite the value for the seed size or whatever you want by recording a script and changing the value to the user parameter after importing the user parameter at the top of the icem script.
set USER_PARA [ic_wb2_get_parameter user_defined XXX]
with XXX being your user defined parameter in ICEM.
Now you can control the parameter from within the Workbench.
This is only working for the ANSYS 14.5 i guess, since only there you can choose a standalone ICEM container on the project schematic.
Matthias
mvoss is offline   Reply With Quote
Old   April 28, 2013, 14:23
Originally Posted by neewbie View Post
hey,
Matthias
Matthias, thank you very much for your response! I'm not using standalone ICEM container, in ansys 14.5 it is possible to fo to ICEM directly from ansys meshing (from Fluid Flow (Fluent) analysis system in project schematic) by choosing method of meshing. Now I found that it is possible to set some global parameters as workbench parameters in the method in ansys meshing. Thus I set Max elem size and everything works now.
I really appreciate that you answered me. I'm sure your advice will help me in future.
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 03:42
calculating output parameter in cfd post markus67 CFX 3 August 26, 2015 09:28
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 09:14
[ICEM] Importing a set of triangles into ICEM CFD rambabu ANSYS Meshing & Geometry 5 November 12, 2009 17:13
