[ANSYS Meshing] Inflation layer stair stepping |
March 1, 2018, 02:33 |
Rep Power: 8 |
I have created a simple 3D geometry of a rocket and enclosed it with a cylindrical fluid domain. I want to create inflation layers along the whole rocket. At first I split the domain along a 90 degree symmetry plane. This allowed me to create inflation layers over the whole rocket. However, when I now want to try to run my simulations without splitting the domain in a symmetry plane I get stair stepping. I have tried changing collision avoidance to layer compression, increasing the maximum angle to 180 degrees, decreasing the gap factor, changing size function, but I still get the same problem. Anyone have any suggestions what else I can try? Attached is a picture of the problem cut at a section plane. //krihamm |
March 1, 2018, 08:45 |
Rep Power: 8 |
Face sizing fixed the problem
January 31, 2023, 22:10 |
Maulana Akbar R
Rep Power: 3 |
Hello krihamm, I am currently facing this same problem (albeit on a hydrofoil tip). May I know which face did you use sizing on to fix this problem? Can we apply it directly to the boundary face in which the stairstep occurs?
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[ANSYS Meshing] 2D inflation layer contains triangles | jones007 | ANSYS Meshing & Geometry | 8 | May 4, 2020 08:42 |
Boundary Layer - Inflation Layer | dlkadk | FLUENT | 0 | September 16, 2017 11:11 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
