[ICEM] 2D Mesh from ICEM to ANSYS FLUENT
Old   May 8, 2013, 05:00
Default 2D Mesh from ICEM to ANSYS FLUENT
Tom Marquardt
TomM is on a distinguished road
Hey guys,
I started to work with ICEM CFD and FLUENT and I got a small problem.
I created a rectangular surface (2D model) in ICEM, created a simple mesh and wrote an output file for Fluent. To this point everything worked well.
I opened Fluent and tried to open the file but then the following text appears and the only thing left of my mesh is a single straight line.
What did I do wrong? Its probably a stupid question but I would be happy about help.
Cleanup script file is C:\\Users\\Tom\\Documents\\Studienarbeit\\cleanup-fluent-Tom-PC-4436.bat
> Reading "C:\Users\Tom\Documents\Studienarbeit\Netz\fluent. msh"...
1485 nodes.
1408 quadrilateral cells, zone 8.
2740 2D interior faces, zone 9.
32 2D wall faces, zone 10.
32 2D wall faces, zone 11.
88 2D wall faces, zone 12.
Building...
mesh
Info: The mesh contains elements that are invalid or of poor quality.
A different numerical scheme will be applied to these elements,
which may affect the quality of the solution. It is recommended
that you consider removing the invalid and poor quality elements
in the mesh.
For more information on the invalid and poor quality elements,
please use the following TUI commands:
/mesh/check
/mesh/repair-improve/report-poor-elements.
Warning: non-positive volumes exist.
materials,
interface,
domains,
zones,
aw
cw
hw
int_fluid
fluid
Done.
Preparing mesh for display...
Done.
TomM is offline   Reply With Quote
Old   May 8, 2013, 14:07
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There are many reasons.
1. Association problem
2. Mesh is not in X Y plane
3. There is some element with high skewness
Some pics would help to identify problem area.
Far is offline   Reply With Quote
Export 2D mesh from ICEM to Fluent enghamed ANSYS Meshing & Geometry 18 August 10, 2015 20:49
[ICEM] ICEM incapable of writing ANSYS input mesh with midside nodes ampa ANSYS Meshing & Geometry 0 April 24, 2013 05:23
[ICEM] Cannot load ICEM mesh in FLUENT htnyc ANSYS Meshing & Geometry 4 July 19, 2012 22:02
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
