[ICEM] Shell meshing with respect line elements
Old   May 17, 2013, 17:27
Default Shell meshing with respect line elements
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
i've got a surface quad mesh from a blocking i did. i want to generate a tri surface mesh while respecting the nodes position so they can me merged automatically. the option "respect line elements" is checked on. but it does not work the nodes are still independent as shown in the picture. is it normal ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   May 17, 2013, 17:43
diamondx's Avatar
Ghazlani M. Ali
ok i tried with tri-tri and it is working. i guess it does not work with quad-quad
Regards,
Ali
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[Gmsh] Conversion Error nuovodna OpenFOAM Meshing & Mesh Conversion 14 October 1, 2010 11:07
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
