[DesignModeler] How can divide surface after boolean?
Old   July 29, 2014, 10:23
Default How can divide surface after boolean?
Keuntae park
keuntae is on a distinguished road
In order to simulation for the flow in an axial fan with a motor and a shrouded duct, design process of geometry is doing (Fig. 1 a, b). (the fan is modeled as a upper cylinder.)
To extract fluid region for meshing, boolean operation is performed. A large cylinder, which include all other parts, is the target body. The fan and the motor, and the duct are tool bodies. After boolean operation, a surface of the fan hub and a surface of the motor are merged because its radius is same (Fig. 2).
However, boundary conditions of surfaces of the fan hub and motor are different. The fan hub should be rotated with constant rpm. On the other hands, the motor should satisfy no-slip boundary condition.
To implement different boundary conditions on the surfaces of the fan hub and the motor, how can divide or separate surface after boolean? Thank you in advance for your response.
Keuntae Park
keuntae is offline   Reply With Quote
Old   July 30, 2014, 03:11
Matthias Voß
mvoss is on a distinguished road
Use the "Imprint faces" or "slicing" options.
mvoss is offline   Reply With Quote
Old   July 31, 2014, 07:48
Keuntae park
Thank you for your help
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Simulation of varying contact angles for a large droplet of water on a surface cp703 CFX 5 July 20, 2013 06:08
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 09:20
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
