[GAMBIT] Thin Plate meshing
Old   June 25, 2013, 03:44
Default Thin Plate meshing
Shinobi is on a distinguished road
Hi all,
I have a structure as in attachment. That is a thin plate 10*10 and thickness 0.05 on which is positioned a parallelepiped with base 1*1 and height 3.
Which is the fast way to mesh this structure in gambit?
I'm interested only Heat transfer, that is my BC must be simple temperature on faces.
Thanks all
Shinobi is offline   Reply With Quote
Old   June 25, 2013, 04:26
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
split your domain at the 1x1x3 basis.
Now you are able to mesh the 10x10x0.5 with cooper, and also the 1x1x3 parallepiped
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 25, 2013, 06:02
Hi max,
I split my domain, I mesh parallepiped but I cannot mesh plate because a surface cannot be meshed.
I translate this surface to see you the problem.
Old   June 25, 2013, 06:21
-mAx-'s Avatar
Maxime Perelli
you have to follow an order:
First mesh one of top faces from parallepiped, then mesh the parallepiped volume.
Now mesh the surface you displayed with the translation (not the translated one )
Pick the thin volume, and select cooper (if not automatically selected).
As sources select the one you meshed, and the opposite one, but don't mesh it.
It should be ok.
Then you just have to set the node distribtion in the depth
Old   June 25, 2013, 06:32
I don't know mesh translation.
Edit, LOL Now I understood what you meant!
All right, only 2 problems:
1) to mesh thin plate, he requires 3 faces: meshed, unmeshed and a face in common with
parallepiped. It's ok?
2)Gambit tell me: "Warning: The desidered meshing scheme of Map could not be maintened by the Cooper tool for face 1 (face 1 is that unmeshed opposite displayed face) when meshing volume. You may want to tryng meshing this face first "
Old   June 25, 2013, 06:43
-mAx-'s Avatar
Maxime Perelli
you translated a surface, right (the blue one) ?
Old   June 25, 2013, 06:59
Yes, I edi last message.
Old   June 25, 2013, 07:04
-mAx-'s Avatar
Maxime Perelli
1) yes sorry 2 surfaces common level, and the opposite (gambit will automatically project mesh on this last surface)
2) it can be that the opposite is not mappable, but you can fix it, by changing vertex type
http://aerojet.engr.ucdavis.edu/gamb...h_face_setvrtx
Old   June 25, 2013, 09:14
that is?
I'm noob.
My vertex become End vertex in this case?
I select face, and after in vertices box I insert 4 vertex of that face?
Or I must change vertex of dispayed face?
Old   June 25, 2013, 09:16
-mAx-'s Avatar
Maxime Perelli
first try to mesh the surface with quad/map
does gambit selects automatically this schema?
If not try to enforce quad/map
If it fails, then check Vertex type: all 4 nodes have to be set as End
Old   June 25, 2013, 09:24
Ok, I solved.
They are vertex side.
This is the fastest way to mesh this cases?
I cannot insert a size function, for example, to automate the process?
Last question.
There's a part in Manual (or other source) where is explained how mesh in this case and in other case?
Because this type of mesh is new for me.
Old   June 25, 2013, 09:26
It meshes with Quad/pave
Old   June 25, 2013, 09:28
-mAx-'s Avatar
Maxime Perelli
you can mesh more quickly with unstrured mesh and size function.
But in your case, you have thin plate, which means your mesh will explose (cell's size) because of the small height.
It is better to handle this plate with cooper (10-20 cells in depth).
But you can try on your own, you will see what I mean.
Old   June 25, 2013, 09:29
-mAx-'s Avatar
Maxime Perelli
It is also ok, but you can enforce with quad map
Old   June 25, 2013, 09:40
Yes, I try... for this I open here this 3d
A source to learn how mesh in several cases with gambit?
Or it is only experience?
Old   June 25, 2013, 09:43
I try:" error bad interval. It recommends submap" but also it generates "unexpected problems".
Old   June 25, 2013, 09:45
-mAx-'s Avatar
Maxime Perelli
Are you meshing all the edges?
Old   June 25, 2013, 09:50
Scheme was:
1)mesh one of top faces from parallepiped
2)mesh the parallepiped volume
3)mesh displayed surface
4)change vertex of opposite face
5)Pick the thin volume, and select cooper as sources meshed face, the opposite one and face in common with parallepiped.
When I mesh edges?
Old   June 25, 2013, 09:59
-mAx-'s Avatar
Maxime Perelli
before meshing the thin volume with cooper, you need to mesh the surface which lies at the height than parallepiped basis.
That means from thin volume you have one cap full meshed (2 surfaces)
Pick those 2 surfaces as source and the opposite (cooper selected).
If Gambit cannot mesh the opposite surface, try to mesh it alone with quad or pave (without meshing edges first)
Old   June 25, 2013, 10:29
I don't understand, so I prefer repeat logic schem.
1)mesh one of top faces from parallepiped (OK)
2)mesh the parallepiped volume (OK)
3)mesh displayed surface with quad/map-->error! I must mesh with quad/pave. After no problem with other steps. How can I solve it?
[ANSYS Meshing] Very thin plate (0.1mm) ICEM CFD bad meshing msormania ANSYS Meshing & Geometry 1 April 30, 2012 07:45
[Gmsh] Meshing thin, curved solids in Gmsh tibich72 OpenFOAM Meshing & Mesh Conversion 0 January 5, 2012 11:05
Problem with meshing long, thin faces in CFX Martin CFX 3 January 8, 2009 20:51
thin extrusion meshing guillaume CFX 7 October 29, 2008 05:39
thin extrusion meshing guillaume FLOW-3D 0 October 27, 2008 18:38
