July 17, 2013, 14:40 |
Two edges instead of one
Ravi Agrawal
Rep Power: 13 |
This may be one of the simplest of gambit, but I am stuck. While subtracting smaller face from bigger one(retaining smaller one), at the interface of both, I am getting two edges generated for the same interface edge. Same is happening in case of volumes(two faces are generated). Can anybody explain this? Problem is, which one am I supposed to select while assigning boundary conditions or zones.
July 18, 2013, 13:34 |
#2 | |
reza
Rep Power: 12 |
July 23, 2013, 00:57 |
Maxime Perelli
Rep Power: 41 |
pictures always help
In memory of my friend Hervé: CFD engineer & freerider |
July 23, 2013, 06:58 |
Ravi Agrawal
Rep Power: 13 |
Thanks for your replies, I have managed to disconnect the edges.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
