Icem mesh error
Like Tree1Likes
  • 1 Post By mezah
Old   August 26, 2013, 18:19
Default Icem mesh error
Amir
Amir1 is on a distinguished road
Hi guys,
I have created my mesh in ICEM and also I have checked the quality and did the smoothing in ICEM.
While checking the mesh it asked me tons of errors reagding unattached edges and etc. I had three options, ignore, create subset or fix it. (The last one only for some of the errors)
I tried either of them, after exporting the mesh in FLUENT, I faced with the following terms:
1. 38 cells have only faces...
2. Check mesh failed
3. check verbosity
Could you please help me...
Thanks in advance
Amir1 is offline   Reply With Quote
Old   August 28, 2013, 13:39
Hazem
mezah is on a distinguished road
Send a message via Skype™ to mezah
Can you attach a photo or the geometry file if this ok with you.
Amir1 likes this.
mezah is offline   Reply With Quote
Old   August 28, 2013, 15:22
Amir
Sure.
I have attached some helpful pictures.
Thanks in advance,
Amir
Old   August 29, 2013, 13:58
Hazem
The pictures can show how the errors look but sure geometry will be needed to check it ,if you are fine with that?
Sorry for the basic question but have you choose the material points for your model or not?
and how did you generate the mesh ?
The errors occured in surface or volume mesh check?
regards
Old   September 3, 2013, 01:16
Amir
regards
Hi Hazem,
Thanks for your reply. the errors occured in volume mesh check.
I used Robust, then Quick and then create the prisms
Best,
Amir
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
