[GAMBIT] Meshing 2D Fins Object
Like Tree1Likes
Old   September 16, 2013, 04:09
Ikhsan
spartacurse is on a distinguished road
Originally Posted by -mAx- View Post
Clearly a connectivity problem
try to connect edges (/All)
If it is not successfull , then you will need to split the "long" edge from bottom domain with each "small" edge from channels (one by on), and after again a connect /all
yeah it was a connectivity problem. I managed to solve it using the latter solution. thanks again.
spartacurse is offline   Reply With Quote
engineFoam with layers - pressure problems when adding layers mturcios777 OpenFOAM Running, Solving & CFD 23 January 4, 2023 21:56
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
[GAMBIT] meshing of wavy fins dldl ANSYS Meshing & Geometry 8 February 18, 2015 13:10
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
