[ICEM] Meshing of 2D cylinder / number of nodes
Old   September 22, 2013, 11:53
Default Meshing of 2D cylinder / number of nodes
Leonidas Siozos-Rousoulis
leonidassr is on a distinguished road
I have been trying to mesh a 2D cylinder configuration in ICEM (according to the following tutorial) and I want to make a denser mesh downstream of the cylinder.
http://www.youtube.com/watch?v=T2Dxa0OZf58
I am thus trying to add more grid points on the downstream edge, compared to the upstream edge.
However, when selecting the downstream edge ("D" on the image) and increasing the number of points (without selecting "copy parameters on parallel edges"), the number of points automatically increases on the upstream edge ("U" on the image) as well.
http://i593.photobucket.com/albums/t...2dcylinder.png
Is there a way round to this?
leonidassr is offline   Reply With Quote
Old   September 22, 2013, 21:22
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
The need to have the same number of nodes ! that copy to parallel edges does not mean it will copy the number of nodes ! it's about the node's law distribution...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 22, 2013, 23:24
Far
Sijal
delete inside block (aka solid) permanently.
Old   September 23, 2013, 05:05
thank you for your answers.
however, the inside block is already deleted.
any other way round to this?
could it be an issue of the way the curves are associated to the surrounding edges?
Old   September 23, 2013, 06:08
Far
Sijal
there is checkbox of delete permanently. Check that box and then delete inside block.
[ICEM] Assigning different number of nodes to parallel edges Rohit ANSYS Meshing & Geometry 3 September 22, 2017 09:16
Cylinder Intake Meshing dbagtbag CFX 11 July 30, 2015 07:59
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
Interpolation (Number of mapped nodes) Sam CFX 3 January 6, 2008 19:51
Number of nodes on block. Felix CFX 0 October 24, 2007 22:26
