November 6, 2013, 07:50 |
Mesh error
Hey,
I'm trying to generate the mesh for a NACA4412 Airfoil... Therefore I use this tutorial https://confluence.cornell.edu/displ...Airfoil+-+Mesh The only difference is that I use a NACA4412 geometry instead of NACA0012. If I generate the mesh I get strange results in the upper right corner (see attached file). I tried it several times from the beginning but the result is always the same Anybody an idea? Thanks for any advice! |
November 6, 2013, 14:19 |
Ghazlani M. Ali
Rep Power: 29 |
I am not an ansys meshing, but I can swear this have been discussed ealier in the forum , just use the search tool or google search using the appropriate keywords. This was discussed more than one time. all the people who followed that cornell tutorial ends up with a mesh like yours. I don't know if the tutorial is faulty... Good luck
November 7, 2013, 04:29 |
Adrian
Is this domain decomposed into individual bodies?
You may have split edges in that block. Check to see that they are all continuous. Also, the Multizone mesher will do a better job here.
www.idacireland.com |
November 7, 2013, 04:48 |
vidyanand
try with edge sizing hard on the upper right ok
November 7, 2013, 05:32 |
Thanks for your responses
I've used Edge sizing hard. I've changed some things, too. Now I'm using 2 Mapped Face Meshing (1. both quarters on the left and the quarter bottom right, 2. upper right one) and now the Mesh looks better, but still not perfect... |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 05:56 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
