[ANSYS Meshing] Meshing error when changing physics
Old   November 12, 2013, 23:47
Default Meshing error when changing physics
Mr.X is on a distinguished road
I can mesh a geometry using mechanical but when i change the physics to CFD I get error saying " The following surfaces cannot be meshed with acceptable quality" even without applying any other meshing parameters. I have tried to clean up the geometry in Design modular but it didn't work.. what might be the reason behind it?
Mr.X is offline   Reply With Quote
Old   November 13, 2013, 04:24
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Switching physics to CFD changes all the default values for the mesh parameters. Also, the shape checking criteria will be more strict. It is therefore of greater importance that you have good quality on your cells.
This is case specific, so we can't really give any advice other than to try different sizes etc. Not without seeing the case, that is.
jrunsten is offline   Reply With Quote
Old   November 13, 2013, 05:01
I imported without cleaning up the geometry and tried meshing. It worked!! So now i am using virtual faces in Meshing for cleaning up geometry instead of face merge in DM. I hope it doesnot make any difference in result.
2d meshing in ansys meshing syler3321 ANSYS Meshing & Geometry 10 November 1, 2012 20:42
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
doubt in meshing: physics jai Main CFD Forum 0 May 9, 2009 07:17
doubt on meshing joe FLUENT 2 September 12, 2005 13:17
Is conformal meshing really an advantage? Alvin Szeto Main CFD Forum 19 June 27, 2003 07:23
