[ICEM] Fixing holes at the end of a wing
Old   December 27, 2014, 05:01
Default Fixing holes at the end of a wing
Chris_321's Avatar
Christian
Chris_321 is on a distinguished road
already Fixed
Chris_321 is offline   Reply With Quote
Old   December 27, 2014, 06:02
davide basso
rolloblues is on a distinguished road
you should define a "thin cut" with the pressure and the suction side of the airfoil.
In order to the thin cut to work you also need to keep the trailing edge curve in a separate part
rolloblues is offline   Reply With Quote
Old   December 27, 2014, 12:30
Chris_321's Avatar
Christian
After setting the edge paremeter from 0.2 to 0.01 to 0.001 im still facing those holes and getting even more error messages.
I tried to fix it with the thin cuts approach but somehow this approach couldnt fix the holes aswell.
Im wondering if its possible to mesh everything with octree meshing, then delete the volume and after that i remesh the fan with tri elements and after that i would mesh the volume with delauny method.
Will this fix my problem?
And if i switch the surface meshing of the fan from tri to quad elements then my quality looks like this.
will this be a problem in cfx?
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
