January 6, 2014, 05:37 |
Opening gambit
Hi, I am having trouble running gambit. I am using gambit 2.4.6 on windows 7 via X-ming. I can open gambit with the main windows present but am not getting proper functionality. I can create geometries etc but nothing appears in the display window. Also the axis is not shown in the display window.
The following is the code that appears: Starting C:\Fluent.Inc\gambit2.4.6\ntx86\gambit.exe -device open -id default_id5732 -new ... Gambit build SP2007051421. VisualID: 54 class: 4 depth: 24 bits_per_rbg: 8 map_entries: 256 Using OPENGL_DEVICE_DRIVER with no standard visual. Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-medium-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-helvetica-bold-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>. Received X Intrinsics Warning <Cannot convert string "-adobe-courier-medium-r-normal-*-*-120-75-75-*-*-*" to type FontStruct>. Received X Error <158: GLXUnsupportedPrivateRequest>. XErrorEvent: display = cng148099:0.0 type = 0 resourceid = 1025 serial = 12918 error_code = 158 request_code = 143 minor_code = 17 Total of 0.48 cpu second(s), 1677128 maximum memory. Any help greatly appreciated. |
January 6, 2014, 06:12 |
help for opening gambit file n Fluent..... | rizwan | FLUENT | 1 | March 22, 2009 22:41 |
problem with opening gambit after upgrade windows | Baker Saleem | FLUENT | 4 | November 5, 2008 03:46 |
Gambit is not opening | soniya | FLUENT | 2 | August 21, 2008 07:25 |
opening a gambit file | Kabo | FLUENT | 1 | October 4, 2007 15:01 |
Opening a mesh file in gambit | Vidya Raja | FLUENT | 17 | September 30, 2006 02:43 |
