[GAMBIT] what's the difference between {split volume} {subtract(boolean)} in gambit
Like Tree1Likes
  • 1 Post By -mAx-
Old   January 8, 2014, 04:36
Default what's the difference between {split volume} {subtract(boolean)} in gambit
yu. yuxuan
yuyuxuan is on a distinguished road
I am the newer of gambit, and I do the exercise according to http://cfd.mae.wvu.edu/mae433/PDFs/F...20exercise.pdf
In the first place, it makes the outer_cylinder splitted by the inner_cylinder. But in my experience, I always do that using Boolean cooperation. what's the difference? Thanks.
yuyuxuan is offline   Reply With Quote
Old   January 8, 2014, 05:06
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
there is no difference, BUT boolean operations only work on real volumes.
If your geometry becomes virtual after some merge or clean operations, then you cannot use Boolean operations. But you can still use split operations (more difficult with virtual than real, but it works).
I only use boolean operations (substrat) for extracting fluid domain from CAD.
yuyuxuan likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 8, 2014, 05:29
yu. yuxuan
If your geometry become virtual after some merge or clean operations, then you cannot use Boolean operations. But you can still use split operations (more difficult with virtual than real, but it works).
I take pleasure in knowing that
and Many thanks for your quick response.
boolean, gambit, split
[GAMBIT] Need help in meshing volume with Cooper mesh scheme in GAMBIT Dinesh_Dhande ANSYS Meshing & Geometry 0 June 3, 2012 05:37
[GAMBIT] Gambit - Problem having shadow wall on volume ejvikings ANSYS Meshing & Geometry 3 March 23, 2012 01:30
Meshing Volume in Gambit for a water turbine Zaqie FLUENT 1 July 24, 2009 01:25
Gambit: Volume Meshing fluentnoob ANSYS Meshing & Geometry 4 May 20, 2009 05:21
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
