February 24, 2014, 16:39 |
GAMBIT edge problem
Sajjad
Rep Power: 12 |
Hi all
I am new to GAMBIT and FLUENT I created vertices by using this journal code: $i = 0 $imax = 5 $inc = 0.0001 do para "$i" init 0 cond ($i .le. $imax) incr $inc vertex create coordinate $i (SQRT($i)) 0 enddo this code creates vertices of the y=sqrt(x) function (create 15974 vertices!!!) So, now I want to create an edge by fitting a smooth curve between all of these vertices( the most appropriate edge form these vertices). What is the most appropriate edge type for the best accuracy?? I tried to create edge with NURBS edge, first I selected all vertices and then I clicked on Apply, but when I zoom on the edge it seems that edge didn't pass between all vertices (the edge has a little distance from the vertices except the first one and the last)!!!! Why?? NURBS edge is useful for this case, isn't it?? what is my fault? |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Gambit error- the edge degenerates into a point | Jai | FLUENT | 1 | September 23, 2006 04:00 |
Gambit face meshing with a common edge | stella | FLUENT | 1 | October 28, 2005 05:09 |
Problem when I run old gambit jou file with new | xfshi | FLUENT | 0 | March 31, 2005 13:03 |
