[ICEM] Need help with ICEM blocking associations |
March 6, 2014, 17:54 |
Rep Power: 13 |
I really need help in creating structured mesh for a hypersonic aircraft model.
I've been trying to make correct associations, however it seems to fail as there's "negative volume" error in CFX. The model and can be seen in picture 1. A friend of mine did help me to create a working mesh for once after messing up with ICEM but when he tried to recreate the mesh, he also failed. The working mesh is in picture 2 (although the quality is not that good at the nose and at the back). Unfortunately we found there's no way to retrace what he did. Can someone help me to show how the association should be done ? Thanks in advance. P.S. I'm really a n00b in structured meshing |
March 7, 2014, 18:45 |
Rep Power: 13 |
UPDATE :
I tried to merge vertices around the aircraft to match its geometry. Then, the association become pretty easy. The premesh seems to be good, however, when I imported the mesh into CFX, I get this error : Unable to import mesh: Invalid local face number (0) for element 6301 in 2D region SURF. Did I do something wrong ? Or ICEM does not allow merging vertices ? |
March 8, 2014, 11:36 |
[ICEM] Tutorial : Blocking of Two types of T-Junctions in ICEM CFD | Far | ANSYS Meshing & Geometry | 5 | August 16, 2016 03:26 |
[ICEM] Structured grid without blocking in ICEM | BahaZero | ANSYS Meshing & Geometry | 19 | March 5, 2013 11:36 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Using Blocking with ICEM (infinity lines appear) | Touré | ANSYS Meshing & Geometry | 6 | August 5, 2012 17:07 |
