[ICEM] Holes in the volume mesh..
Old   March 6, 2014, 18:44
Default Holes in the volume mesh..
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Dear colleagues, here I come with a question, that maybe you have dealt before.
My domain has at one end a sharp end, in other word like a line, you will see it in the following pictures.
The process arise when I try to make the volume mesh. At this stage some holes appears at that end and of course the mesher files in that section, indeed the software gives an error in that stage. If I turn on the mesh the final mesh is a mess, and off course the mesh finish out of the domain in one case and If I do the surface mesh the hole just appears. As a result If I do the mesh from the surface mesh, the final mesh fail...
What do you recommend me to overcome this problem=???
I attached some pictures.
juliom is offline   Reply With Quote
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[GAMBIT] most efficient mesh for a combustor with holes perdita ANSYS Meshing & Geometry 2 November 17, 2010 04:48
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
