[GAMBIT] Increase number of cells and file conversion |
March 27, 2014, 07:41 |
#21 |
Rep Power: 12 |
Still the same error, I deleted all the volume mesh and just work with fluid-5.
March 27, 2014, 07:52 |
#22 |
Maxime Perelli
Rep Power: 41 |
again: delete all volume mesh (also mesh from fluid-5)
Then mesh surface 1 and 6 On your first picture I see a mesh on surface 4 >> Mesh on surface 1 and 6 will be projected on surface 4. And it can only work if surface 4 is not meshed
In memory of my friend Hervé: CFD engineer & freerider |
March 27, 2014, 08:08 |
#23 | |
Rep Power: 12 |
I checked the meshing on fluid-4 as well, just to check with you, is it the same mesh like on fluid-5? Means this two volumes have independent meshing on its respective fluid volume? So in order to increase the cell numbers, i need to play with the "interval size" figure? But, if I would like to keep the meshing volume meshing for fluid 2 and 3 but play with fluid 4 and 5. Is it possible? Because I need the whole mesh to be meshed. I need to remove only the volume mesh for fluid 4 and 5 and continue with what you taught me above. Am I right with this? What should I do if I need to remain fluid 2 and fluid 3 mesh? |
March 27, 2014, 08:15 |
#24 |
Maxime Perelli
Rep Power: 41 |
if fluid-5 is already meshed, you see that face.5 is common between fluid-5 and fluid-4. That means, you have no more control on the mesh in x-direction (because of face.5).
So for meshing fluid-4, you only have to mesh surface.8 And so on...
March 27, 2014, 08:21 |
#25 |
Rep Power: 12 |
Thank you so much for your patience in teaching me. I will give it a try. Will ask for help again if I face any difficulties.
March 27, 2014, 23:35 |
#26 | |
Rep Power: 12 |
What should I do if I need everything to remain the same except for the meshing on/within fluid-5? |
March 28, 2014, 00:25 |
#27 |
Maxime Perelli
Rep Power: 41 |
maybe you simply didn't mesh fluid-2
March 28, 2014, 01:04 |
#28 |
Rep Power: 12 |
Actually, this mesh is passed to me which is created by an anonymous user.
You meant fluid-2 is not mesh originally before I start editing? But I check with the display attributes with every mesh turned off and turned on only fluid-2 and it showed meshing around that area. For face-1 and 6, I tried to remesh with the same element and type as previous original one with smaller interval size. Face-1: element: quad; type: map Face-6: element quad; type: tri-primitive However, I only managed to mesh the surface of face-6 but for face-1, I faced an error. Must it be type of pave? Possible for me to keep to the original meshing type? |
March 28, 2014, 01:56 |
#29 |
Maxime Perelli
Rep Power: 41 |
if you really want to see if all your volumes are meshed, use examine mesh panel.
Indeed, but turning on mesh visibility you may see a yellow mesh which means surface mesh. BUT a gold color means volume mesh. Anyway the error you get means that face.1 has an edge which is already meshed., so you are no more free to mesh it as your wish
March 28, 2014, 02:34 |
#30 | |
Rep Power: 12 |
March 28, 2014, 02:47 |
#31 |
Maxime Perelli
Rep Power: 41 |
if you want such a refinement http://www.cfd-online.com/Forums/ans...tml#post482414
then yes you have to remove all the mesh, because they are "linked" (face mesh projection)
March 28, 2014, 03:13 |
#32 | |
Rep Power: 12 |
On the other side of note, is it possible to do edge meshing instead of face mesh then to volume mesh? |
March 28, 2014, 03:30 |
#33 |
Maxime Perelli
Rep Power: 41 |
*once fluid-5 is meshed, you can also mesh the other.
*you can also mesh edge if you want, but after you have to mesh surface, then volume If you directly mesh Volume (without meshing surfaces and edges), then gambit mesh them (surface & edge) automatically
March 28, 2014, 06:13 |
#34 | |
Rep Power: 12 |
I removed all volume mesh. Then I changed the mesh on face-1 with interval size of 0.2, then volume mesh fluid-5 using face-1&6 with inteval size 0.2. Then surface mesh face-8 with size interval of 0.2 then volume mesh fluid-4 with interval size 0.2. Then how should I mesh fluid 2 (hex + tet primitive) & 3 (hex + submap)? |
March 28, 2014, 06:38 |
#35 |
Maxime Perelli
Rep Power: 41 |
volume fluid-3 has to be splitted in order to get quick hexa mesh
Untitled3.png volume fluid-4 will be more difficult (but you meshed it with tetra)
March 28, 2014, 07:00 |
#36 | |
Rep Power: 12 |
How you should I split it (Split the face or mesh)? Mind teaching me? Is it fluid-2 or fluid 4 you are refering in reference to fluid-4 stated above? Then what's the possible way for me to mesh everything correctly with the default elements and type from original mesh? Actually, this mesh is passed to me which is created from an anonymous user. That's why I am having a hard time to refine it. |
April 5, 2014, 09:26 |
#37 | |
Rep Power: 12 |
Max, I need help in defining the boundary conditions. I got error when I am trying to set the conditions for fluid-2,3,4 and 5 as the entity but others was alright (others using face as entity). But I check and the mesh is actually volume meshed. Can I know why? Thank you. |
April 7, 2014, 00:56 |
#38 |
Maxime Perelli
Rep Power: 41 |
explain what kind of bc did you set on which surface or volume
April 7, 2014, 03:45 |
#39 |
Rep Power: 12 |
below stated are what I did, using the mesh file attached here.
https://dl.dropboxusercontent.com/u/38924025/Mesh.zip renaming continuum types: [name -> new name , type] fluid-2 -> bowl , fluid fluid-3 -> crevice , fluid fluid-4 -> cylinder , fluid fluid-5 -> nearliner , fluid defining boundary conditions: [name -> face(f)/group(g), type] blowby -> f11 , wall cylinderhead -> f4 , wall cylinderhead:015 -> f8 , wall default_interior -> f6 , interior default_interior:019 -> g3 (select volume - fluid-3) , interior default_interior:020 -> f9 , interior default_interior:021 -> g2 (select volume - fluid-2) , interior default_interior:022 -> g4 (select volume - fluid-4) , interior default_interior:023 -> g5 (select volume - fluid-5) , interior liner -> f9 , wall liner:016 -> f13 , wall piston -> f22 , wall piston:017 -> f1 , wall piston:018 -> f14,f15,f16,f17,f18,f19 , wall symmetry -> f3, f2 , symmetry symmetry:011 -> f7, f10 , symmetry symmetry:013 -> f21, f23 , symmetry symmery:014 -> f12, f20 , symmetry For boundary conditions, I select "groups" under entity, select the respective volume under group creation. However, I got error while exporting the conditions that involve the groups entity such as default_interior:019, default_interior:021, default_interior:022 and default_interior:023. |
April 7, 2014, 07:39 |
#40 |
Maxime Perelli
Rep Power: 41 |
you don't need to specifiy interio BC.
Gambit will treat them automatically. The same with Wall- Question, where flows your fluid in and out?
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
AMI interDyMFoam for mixer | danny123 | OpenFOAM Running, Solving & CFD | 4 | June 19, 2013 04:49 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
