[Other] extracting the curve in cartesian format |
July 7, 2014, 23:56 |
tmeysam92
i have the stp. file of a pump. i want to extract the curves of the blade in Cartesian format. i mean the data of the curve should be saved in x,y,z format. how can i do that? in solidworks? catia? or ... i want to import the curves to turbo grid and cfturbo. |
July 8, 2014, 19:56 |
Sebastian Engel
Rep Power: 20 |
the following idea might not the easiest solution. You could try to mesh the desired curves just with line elements (in the edit mesh menu). And then, export the line mesh in an ascii mesh format of your choice. With regards, Sebastian |
[ICEM] Extracting geometry information from Plot3D File Format | Crank-Shaft | ANSYS Meshing & Geometry | 10 | February 18, 2016 14:11 |
[DesignModeler] Using ".txt" format to generate 3d curve - pls help! | suryajagan77 | ANSYS Meshing & Geometry | 0 | May 31, 2014 03:37 |
[ICEM] Extracting point data from a spline or curve | sherifkadry | ANSYS Meshing & Geometry | 2 | December 5, 2010 20:20 |
Tecplot output format in 2-D cartesian grid | jinwon park | Tecplot | 5 | April 7, 2008 06:28 |
