July 29, 2014, 09:05 |
Hybrid Mesh on 2D airfoil
Rep Power: 11 |
Hi everybody
I'm a new user of ICEM CFD and I'm trying to do an hybrid mesh around an airfoil, but I have some problems. I had look at lots of other post on this subject in this forum but I didn't found the solution. I want to have a quadra boundary layer and a triangular mesh around, like on the first picture attached to this message. I have something very closed but I have some issues with the trailing edge. Being not a usual user of ICEM, maybe my mesh method is wrong. I did: - Create a rectangular(*) farfield around my airfoil - Create a surface (fluid) on this farfield, then segment this surface at the airfoil curve - Delete the airfoil surface (so I have a airfoil shaped hole on my fluid surface) - Build Topology - Then Mesh with the following parameter: Global Mesh Setup: All Tri, Patch Dependent Part Mesh Setup: max size Farfield:1 , Fluid: prism and int wall option selected (not max size specified) -Then curve mesh setup to specify the boundaries conditions that I want. So I don't know how to have a better mesh near the traling edge. Thank you in advance for your response. Jeremy *If I do a circular farfiled, I am unable to segment the surface into a farfield surface and an airfoil surface and then to have an airfoil shaped hole in my fluid surface... I don't understand why It doesn't work with a circular surface... |
August 12, 2014, 06:22 |
Rep Power: 11 |
A little bit of help please
Regards, Jeremy |
airfoil, airfoil2d, hybrid |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
[ICEM] How to do 2D hybrid mesh around hydrofoil | jaber | CFX | 2 | January 3, 2013 18:11 |
[ICEM] Need urgent help for hybrid mesh generation | Pursuor | ANSYS Meshing & Geometry | 1 | August 29, 2012 16:04 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
