[ICEM] Y blocking and O grid
Old   August 14, 2014, 23:41
Default Y blocking and O grid
Govindaraju
kmgraju is on a distinguished road
Dear all Please find the attached geometry
I did Y blocking and O grid operation . I am not sure what I am doing is correct or not? Please help me If I made a mistake in my model
The ogrid created along the edge is not satisfied it is (/) upward direction . I think it should be (\) like this. I am new to this software I struggling Please help me
kmgraju is offline   Reply With Quote
Old   August 15, 2014, 04:57
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
I am curious as to why you tried to create the O-grid along each of the branches.
I personally would've tried to just use 'Index Control' and then split along the central line along each branch. This can simply be done by extending the splits from the Y-grid at the intersection.
This would still result in hexahedral cells over the entire domain without the additional O-grids that you included.
My 2 cents.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   August 15, 2014, 06:02
Govindaraju
My 2 cents.
Dear Crank shaft
If I didnot do the O grid operation the mesh pattern is some like in the picture
[ICEM] o grid blocking strategy? icemaniac178 ANSYS Meshing & Geometry 14 March 19, 2013 23:18
[ICEM] Structured grid without blocking in ICEM BahaZero ANSYS Meshing & Geometry 19 March 5, 2013 11:36
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] Split O grid BrolY ANSYS Meshing & Geometry 1 July 2, 2010 09:23
Blocking of Grid to a certain height is possible? jogendra FLUENT 2 October 19, 2005 03:20
