I have big trouble in meshing the space of a hollow cylinder |
September 7, 2014, 13:12 |
Zhuo
Rep Power: 11 |
when I used workbench of ANSYS,I cannot mesh the space of my stuff. it's like a hollow cylinder(image), after generate mesh, I wanna get the grid inside the cylinder, not only the surface. can anyone told me how to solve it ?
September 8, 2014, 12:46 |
#3 | |
WALI HASAN
Rep Power: 12 |
i think u want like that .... |
September 8, 2014, 15:43 |
Adriana
Rep Power: 11 |
To get mesh inside you must have something inside your cylinder. For instance if you want to mesh a fluid inside your cylinder, then you create two bodies: a solid body (your hollow cylinder) and then you create another body which will occupy the inside cavity of the cylinder (which will be a fluid body). This way you should be able to get mesh both inside the cylinder and on the sides of the cylinder. Adriana Druma Aavid Thermalloy San Jose, CA |
September 8, 2014, 19:24 |
Zhuo
Rep Power: 11 |
September 8, 2014, 19:26 |
Zhuo
Rep Power: 11 |
September 8, 2014, 19:37 |
Adriana
Rep Power: 11 |
K-omega SST is just a stronger turbulence model. Usually gives better convergence for something where k-epsilon doesn't work. But I believe if you refine your mesh, you will be able to convergence. Is this a steady-state or transient simulation?
Adriana Druma Aavid Thermalloy |
mesh 3d |
Cylinder Intake Meshing | dbagtbag | CFX | 11 | July 30, 2015 07:59 |
[ANSYS Meshing] Meshing 3d circular cylinder in ICEM | darazsbence | ANSYS Meshing & Geometry | 0 | March 11, 2014 16:35 |
[blockMesh] Problems meshing a half of a cylinder with blockMesh | zfaraday | OpenFOAM Meshing & Mesh Conversion | 2 | December 11, 2013 03:41 |
meshing on cylinder fails ICEM | potac | ANSYS Meshing & Geometry | 0 | October 25, 2011 05:21 |
small cylinder and big cylinder | Eric | CFX | 1 | January 26, 2007 05:38 |
