[ICEM] how to block a 120 degree part of a 2D vawt
Like Tree2Likes
  • 1 Post By mikebausas
  • 1 Post By GIJOE_hun
Old   August 6, 2013, 04:05
Default how to block a 120 degree part of a 2D vawt
Michael Bausas
mikebausas is on a distinguished road
Can anyone please help me on how to block a 120 degree part of a 2D vawt? I will be doing a thesis work on the performance of cambered airfoil but I am still on the stage of learning ICEM CFD to genereat my mesh.. Thanks
mikebausas is offline   Reply With Quote
Old   August 7, 2013, 03:35
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
1. Create main block.
2. Associate edge and vertices.
3. Make four splits at leading edge, trailing edge, pressure side and suction. 4. Make O-grid around airfoil.
5. Set edge mesh parameters
6. Create UN-structured mesh.
7. Select solver and set boundary conditions
8. Output mesh.
Far is offline   Reply With Quote
Old   August 15, 2013, 00:25
Michael Bausas
thanks Far, but if you wont mind, i would like to request if you can make a step by step video tutorial on which edge and vertices should be associated to which curves and points. and the locations of the splits. Sorry but i am still lost with ICEM CFD. Thank you so much in advance.
Old   September 26, 2013, 03:30
Michael Bausas
Far, good day! I have successfully built my unstructured mesh for 1/3 portion of wind turbine.. My question now is how to make the whole three bladed rotor.. Do i have to copy rotate the geometry, blocks and mesh? or only the mesh?
I have tried copy-rotating the mesh but line elements would only appear for the original 1/3 part of my turbine. I am aware that i need to merge the nodes in order to generate the line elements for the whole rotor, but i think i am doing it wrong. I want to ask which nodes do i have to select to merge? thanks Far for your constant help..
mlberens likes this.
Old   October 2, 2014, 11:33
Molnár Bence
GIJOE_hun is on a distinguished road
Hi Michael!
Have you found the solution how to copy and rotating properly the mesh from the 1/3 part? I don't know it neither and it would be a great help if you could tell me, and I really appreciate it.
Thanks in advance!
Regards,
Bence
GIJOE_hun is offline   Reply With Quote
repair surface problem sieginc. STAR-CCM+ 13 February 25, 2018 19:23
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 13:30
what boundary condition is proper for simulation of shock-tube low pressure part? immortality OpenFOAM Running, Solving & CFD 0 May 2, 2013 13:22
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 09:20
A mesh block with three mesh block to use the difference? degr FLOW-3D 3 June 26, 2009 14:51
