[ICEM] Unnecessary mesh in the hole
Old   September 16, 2014, 10:30
Default Unnecessary mesh in the hole
erdal
erzdemir is on a distinguished road
I created below meshing but there are element created in the hole also due to middle block I presume, how can I prevent this situation?
erzdemir is offline   Reply With Quote
Old   September 16, 2014, 15:58
Sebastian Engel
bluebase will become famous soon enough
hmm... deleting the blocks in your hole?
Edit:
Just saw your first thread... Is the mesh 2d? And are you sure you only selected the "hole block" for your o-grid?
bluebase is offline   Reply With Quote
Old   September 16, 2014, 20:39
erdal
It is 3D and I only select hole block for hole grid
Old   September 17, 2014, 03:09
Sebastian Engel
Ah 3D!
when you select the around block option, the o-grid will be generated around all faces, also above the top face and the buttom face.
To avoid that, remove your o-grid, or start over, and then select the block in the hole again. Additionally, use the select face option to select the top and buttom face of the block in the hole. Check the around block option and generate the o-grid.
That should do it.
With regards,
Sebastian
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh eddyy19g ANSYS Meshing & Geometry 3 February 13, 2014 09:36
[ICEM] ICEM CFD Cooling Hole Hybrid Mesh RealENG22 ANSYS Meshing & Geometry 1 November 22, 2013 22:27
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
