[ANSYS Meshing] Two Domains - Interface Recognized |
September 23, 2014, 09:30 |
Daniela Passos
Rep Power: 11 |
Hello, good morning.
I created a tetra mesh that have two fluid domains (oil and water). How can I create a material point or body in the tetra mesh for that the interface of the two domains be recognized by CFX-Pre? Can anyone help me? Thanks in advance. |
September 23, 2014, 11:27 |
#2 | |
Amin
Rep Power: 14 |
I don't understand your goal fully! but if you want using an interface between 2 faces of 2 various zone, you must define a connection between the faces in ANSYS Meshing! |
September 23, 2014, 11:49 |
Daniela Passos
Rep Power: 11 |
Amin.z,
My problem is a catenary riser with a marine domain around. But I need study a fluid flow inside of the tube with a presence of leak orifice through which the fluid will leave and I will can study the dispersion on the sea. The difficulty is the CFX-Pre recognize the interface between the tube and the marine ambience once the two domains will be fluids. ---- Thanks |
September 23, 2014, 12:43 |
Amin
Rep Power: 14 |
still unclear!
do you have one face at face of tube and want to have 2 separate faces!? or you have 2 separate faces, but you want define an interface between them and CFX does not recognize them? |
September 23, 2014, 14:06 |
Daniela Passos
Rep Power: 11 |
Yeah... I want define an interface between them... it's just one shared surface that I define as "wall" at CFX-Pre but CFX doesn't recognize as "internal fluid - wall" and "wall - external fluid"...
September 23, 2014, 15:17 |
Amin
Rep Power: 14 |
You should have 2 separte faces between the zones!
Do you use Ansys geometry for modeling? Do you use form new part in its? I don't know about setup in cfx, but in fluent we should have 2 different faces and connect them in ANSYS meshing with using connect! |
September 24, 2014, 07:36 |
Daniela Passos
Rep Power: 11 |
Ok, Thank you!! I will try this!!!
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
