[ICEM] penetrating edges by rotation
Old   October 9, 2014, 15:35
Default penetrating edges by rotation
jason
jason_31 is on a distinguished road
hey guys,
I'm having some issues wih ICEM. I'm trying to rotate a 2d mesh into 3d by rotation at the x-axis. The problem is that I always encounter the error: penetrating elements. Can you guys plz help me. I've attached a picture of the error. Also I've made sure that I've associate the edges to the curves and points to vertices. So association shouldn't be a problem. As you'll see on the pic, the error occurs only at the x-axis which is the axis of rotation.
Thanks
Jason
jason_31 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
