[ICEM] Blocking stratery
Old   November 27, 2014, 02:03
Default Blocking stratery
Pavel
SuperPahan is on a distinguished road
Send a message via Skype™ to SuperPahan
Hello!
I built a simple geometry for training blocking method in ICEM. When I split one initial block for creating block structure, there is no questions. But when I create blocks separetly, one after another, with the merge option, the mesh from middle block sandwiches on the mesh from neighboring blocks.
I understand that in case of a simple geometry it is better to split one initial block. But in case of a big assembley it is better to create blocks separetly.
How can I avoid mesh sandwich in case of creating blocks separetly? May be delete face...?
SuperPahan is offline   Reply With Quote
[ICEM] Blocking wali ANSYS Meshing & Geometry 2 September 8, 2014 14:19
[ICEM] Problem to load the blocking biasilveira ANSYS Meshing & Geometry 2 February 24, 2013 22:04
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 17:27
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 04:46
