[ANSYS Meshing] execution error occurred inside the mesher (Linux) |
December 14, 2014, 13:14 |
Rep Power: 14 |
When I use ansys meshing in linux machine, I get this error message (The process suffered and unhandled exception or ran out of usable memory). RAM in linux machine should be enough. But, I can mesh the same geometry by using windows machine with much less RAM.
It seems ansys meshing create large temporary file to my home directory (which has limited size). '.ansys' file? Could you give suggestion how to move the large temporary file to another disk place? Thank in advance! |
December 14, 2014, 17:49 |
Rep Power: 11 |
Are you sure that .ansys is a regular file, not a directory?
You can try to create a directory called .ansys on any disk where you have enough space and create a symbolic link into your home directory. |
December 15, 2014, 00:48 |
How to make a symbolic link
Rep Power: 14 |
Thank you very much!
Your are right '.ansys' is a directory. Could you give a simple example of this symbolic link? |
December 15, 2014, 04:38 |
Rep Power: 11 |
Of course.
first, move .ansys to a place where you have enough space by opening a terminal and type in: Code:
mv ~/.ansys /media/some/big/disk Code:
cd Code:
ln -s /media/some/big/disk/.ansys .ansys |
December 15, 2014, 05:40 |
with problme
Rep Power: 14 |
Thanks a lot!
I tried the link as you suggested. But it still writes the file to /home/.ansys directory. Not to the big disk. |
December 15, 2014, 07:31 |
Rep Power: 11 |
If you execute
ls -al ~/.ansys if it's a link, the first part of the output should look like lrwxrwxrwx if that's the case, you will see the files inside there but they are stored on your large storage device. You can check the disk usage with Code:
df -h |
December 15, 2014, 07:42 |
it is a directory
Rep Power: 14 |
.ansys is a directory. I can not remove all the hiden file in this directory.
I want to remove all the files, and delete this directory. Then to have a link. But I do knot know how to do it. |
December 15, 2014, 07:48 |
Rep Power: 11 |
to delete the directory .ansys and all data in it
rm -rf .ansys Code:
mkdir /place/for/new/.ansys Code:
ln -s /place/for/new/.ansys .ansys hope that helps |
December 15, 2014, 13:03 |
#9 | |
Jace
Rep Power: 15 |
I encountered that problem before on Windows, try right-clicking on the mesh in the work tree, and there should be an option similar to "clear the mesh data". That will free up those memories and you can create the mesh again. |
February 27, 2017, 06:32 |
#10 |
Lorenzo Mazzei
Rep Power: 15 |
This operation can help, but non always. In my case I was able to mesh the domain only deactivating the automatic proximity refinement.
ANSYS Workbench on Linux | CPUcruncher | ANSYS | 4 | July 11, 2010 09:19 |
compatibility problem of UDF on LINUX | manu | FLUENT | 4 | December 19, 2007 04:58 |
Linux to Windows (dual boot system) | Alex | Main CFD Forum | 9 | May 3, 2007 03:36 |
Help!!! mpt_connect: error on linux amd64 Help!!! | Mauro Sc | FLUENT | 0 | December 18, 2005 04:51 |
mpt_connect: error on linux amd64 | mauro sc [gd] | FLUENT | 0 | December 16, 2005 18:32 |
