[ICEM] Changing global axis in ICEM
Old   December 23, 2014, 13:32
Default Changing global axis in ICEM
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
I am currently using ANSYS 15.0 suite and I do all meshing through ICEM CFD, for automotive aerodynamics.
My basic workflow involves importing a Parasolid (x_t) file and then creating the multi-block structured mesh, to export to a CGNS format for external use. I currently have a mesh which is gigantic and the domain is decomposed into 242 blocks, which became 484 blocks after using a mirror mesh feature.
Unfortunately, I realised that my origin is at the wrong location and I'd like to have it moved to the wind-tunnel floor rather than the tip of the vehicle. I am really hoping that there's an easier way to achieve this through ICEM than to go ALL the way back to the geometry and working through the painstaking process again.
Please inform us if there is some way to move the origin to the bottom prior to exporting to CGNS. I know how to re-orient the local axes for the individual blocks in the mesh, however, is there a similar way to modify the location and orientation of the global coordinate system prior to CGNS export?
Link to Files
Thanks in advance.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   December 23, 2014, 22:23
kad
kad will become famous soon enoughkad will become famous soon enough
Should be no problem. You can move the mesh to your desired location under "edit mesh". So convert your blocking to unstructured mesh and use the function for transforming mesh. No need to transform geometry or blocking.
kad is offline   Reply With Quote
Old   December 23, 2014, 23:24
Ovi
Thanks for your prompt reply. I have followed this method and found that the mesh is translated however, the original blocking and geometry is maintained in the same location. This could possibly be an advantage.
I will try out the final exported mesh in our solver and hopefully it will all work well!
Thanks for your assistance once again.
Sydney, Australia
Old   December 27, 2014, 00:04
Ovi
Here is a follow-up question -
When creating a mesh for a relatively simple geometry, all of the blocks in the pre-mesh correspond to a domain in the final multiblock, structured mesh. However, when using a transformation to create the final mesh, such as for a symmetric geometry, I've had some difficulty in reorienting the individual local axes for the mirrored domains.
On the original blocks that were explicitly created, I have the option of changing the origin of the local axes however, on the mirrored domains, I am only able to swap i,j,k and can't change the location of the origin. Is there a better way to do this.
Thanks
Sydney, Australia
Old   June 6, 2020, 22:55
bestucan's Avatar
Tu Can
bestucan is on a distinguished road
mesh could be transformed, so does geometry.geometry->transform geometry.
bestucan is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Changing axis in Histogram plots Andrea1984 Tecplot 1 April 30, 2014 11:46
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
