[ICEM] mesh
Old   February 13, 2015, 03:31
Default mesh
wave maker
wave maker is on a distinguished road
hello, first of all i want to excuse for my not perfect english.
i want to generate a mesh and a refinement like this:
https://www.dropbox.com/s/l0ltjlir57na8br/mesh.png?dl=0
but i am not clever to use icem. somebody could help me and could give me any steps to accomplish my wok??
thanks a lot
wave maker is offline   Reply With Quote
Old   February 13, 2015, 03:53
Umberto
cinclus is on a distinguished road
It's not the best picture you could upload.
You have to start from the geometry, then, using hexa, apply blocks per each region of your field.
It's plenty of posts here concerning the subject
cinclus is offline   Reply With Quote
Old   February 13, 2015, 04:17
wave maker
maybe with these two pictures it's clearer:
https://www.dropbox.com/s/aiz6wh8po6...mesh1.png?dl=0
https://www.dropbox.com/s/7hsn321x4h...mesh2.png?dl=0
where do i set the dimension of the single element in icem????
i am not able to compute the mesh in this way with the refinement shown in the figure. how can i compute that????
thanks a lot
Old   February 16, 2015, 05:56
Sebastian Engel
bluebase will become famous soon enough
Hi wave maker,
i suggest you to do the few hexa tutorials comming with ICEM.
Anyway, in icem you cannot set a single element size other than the first cell height of an edge. In edge parameters you can set the spacing.
Creating the desired mesh is very easy. Create your geometry. Then split the short edges into three blocks. Move the edges of the center block to desired postion. Set your cell counts for the blocks. And now, use a handy feature to match spacing from the peripheral blocks to the center block. This feature can be found in the same menu as edge params.
with regards,
Sebastian
bluebase is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
