[ANSYS Meshing] Jscript Command to add Mesh Method in Meshing |
April 28, 2015, 02:41 |
Rep Power: 11 |
What is the command to add Mesh Method in Ansys Meshing?
Also what are the commands to control Span Angle Center and Inflation options (all global mesh settings commands)? |
April 28, 2015, 18:26 |
Rep Power: 14 |
Hi Kar,
Have you tried finding functions on your own first? if not then please try first and then ask questions! You may go to Ansys folder in your C drive and search for functions in JS files I am sure you will find all the functions you are asking for! Hope it helps Cheers KAPI |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Other] Add / remove cell layers (dynamic mesh) | ChristophGradl | OpenFOAM Meshing & Mesh Conversion | 9 | April 8, 2021 04:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
