[ANSYS Meshing] Difference between edge and wireframe
Old   May 7, 2015, 07:48
Default Difference between edge and wireframe
Sergio
srg_01 is on a distinguished road
Hi!!
I'm new user of ANSYS 14.5 and I meet with the following problem:
-with the Design Modeler I import my .IGS file and I create the surface to work (picture designmodeler.png)
- when I go to create the mesh, the edge in this zone mismatch with the wireframe (picture meshing1.png) with the consequence that the mesh isn't well created in that area (pic meshing2.png).
Anyone know how can I resolve the problem??
Thank you so much.
srg_01 is offline   Reply With Quote
Old   May 7, 2015, 08:50
Hydreaulic structures
hamidciv is on a distinguished road
hi sergio
whether your geometry model consist of one part? i think you dont setting geometry in one part.
hamidciv is offline   Reply With Quote
Old   May 7, 2015, 13:33
Sergio
Hi hamidi! Thanks for your response.
my .IGS geometry consists in one solid which I create a surface from one face of it. I suppress the body and I only work with the surface created which it is what I'm meshing.
I don't know if I'm responding good your question...
Old   May 7, 2015, 14:27
dear sergio , whether you goal do make mesh in surface? you used what kind of mesh? please attach image all geometry consist of solid and surface body without supress.
Old   May 8, 2015, 07:57
Sergio
I attached my solid and the surface that I need to work (I only need a 2D analysis).
I used triangles method because the others method, report me errors in this surface.
I think it's no problem with the mesh, the problem is before because it doesn't recognize well the edges when it import in the pass from DesignModeler to Meshing.
Old   May 8, 2015, 08:57
yes probable your geometry have a one problem, i drawed one simple model consist of surface body and solid body like your geometry and i have not problem in meshing, unfortunately with image find problem not easy, if your possible put igs format in here, when you used other kind of mesh other than triangle, what error Receive you? i suggested you go in virtual topology and put behavior on high and click generate, whether you done this work?
Old   May 9, 2015, 12:41
Sergio
I attach here the .igs model
https://mega.co.nz/#!fd4SGKJJ!S7hhbA...1m4CyOuV5VrMa8
When I used other type of mesh ansys reports me this errors (attached pics), and when I used a virtual topology this is the result (attached pic).
In any of the ways the error isn't corrected...
Old   May 9, 2015, 14:08
dear friend
geometry that you attached only consist of body and any surface body, In any case your geometry is made small faces that this can affecting on Bad quality elements of mesh, you should merge this face smalls and if your problem not solved modified your geometry.
hope it helps
Old   May 12, 2015, 06:55
Sergio
Ok. I'm going to try it.
Thanks for all!!
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
