[ICEM] Meshing the elbow including guiding vanes
Old   June 25, 2015, 05:33
Default Meshing the elbow including guiding vanes
Eduardo Hoefler
hefy is on a distinguished road
Members of the professional community please advice. I am engaged in meshing of the compact inlet elbow with three guiding sheet vanes. In the middle of the outflow cross-section is located a protective tube, which on the upper side penetrates the outer casing of the elbow. In the attached figures it is presented one-half of an elbow, sectioned along the plane of symmetry. I hope that every significant detail is visible.
In the central part of the elbow, with presented vanes, the mesh is designed with tetra elements, but I'm more interested in hexahedral mesh – applying ICEM CFD. I am wondering how to design the blocks with the final goal that the whole elbow is one domain with hexahedral mesh element? Is it worth or not to insist in this idea?
Thanks
hefy is offline   Reply With Quote
Meshing software comparison Wikie Mesh Generation & Pre-Processing 5 September 29, 2014 06:09
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp Crank-Shaft ANSYS Meshing & Geometry 0 January 11, 2013 05:48
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 11:58
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 11:56
