[ANSYS Meshing] Remove faces from defined selection |
July 3, 2015, 10:54 |
Rep Power: 16 |
Hello the image attached represent a finned tube part with hiding the water and air regions. My question I need to remove two faces from the interface boundary using the option (Remove from current selection) but I think it not work properly when I press over the faces it seems the boundary still the same without removing the faces I select? what the problem?
Thanks mariam |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
