[ANSYS Meshing] Hexa mesh with Ansys Meshing possible?
Old   July 24, 2015, 11:25
Smile Hexa mesh with Ansys Meshing possible?
Oleg
olegmang is on a distinguished road
Hi everyone.
I haven't been doing much of CFD for quite a long, so it's a long time since I've been here and it's good to be back. Currently I've faced with one problem/task - is it possible to do the hexa meshing for the turbomachinery with ANSYS Meshing? Far and PSYMN showed that it's definitely possible with ICEM CFD, but what about ANSYS meshing?Had anyone tried to do this with it? I tried to look through the forum, but no luck .
What I'm particularly interested is to get the hexa mesh of the radial turbine flow channel with prism layers on hub, shroud and blade. Here is the example of the geometry.
https://drive.google.com/folderview?...1E&usp=sharing
What I tried so far:
1) sweep the mesh from hub to shroud and viceversa. The result is the same - because of highly twisted blade the mesh has skewed elements
2) slice the channel with the meridional surface and used Multizone method. This gave me a better results, as I was able to get hexa in the flow core with prizm layers around the blade and tet prizm layers at hub and shroud. Though I'm still strugling with it as it it too touchy.
Any ideas of how to make my dream come true?
Regards,
Oleg
olegmang is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
ANSYS Meshing Mem Usage Seems High for 7 million Element Mesh jonny_b ANSYS Meshing & Geometry 2 August 15, 2011 08:39
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
ANSYS Meshing - DC Mesh Quality alven299 ANSYS Meshing & Geometry 5 July 19, 2010 11:34
