July 25, 2015, 21:53 |
Delauney volume mesh going wrong
Rohith Giridhar
Rep Power: 11 |
Hi All,
I am creating a mesh for a blade that is placed in a domain. The blade has a trailing edge with a small thickness. I am trying to create my volume mesh by first creating a patch dependent surface mesh and then using a Delauney volume mesh over this. I have obtained my patch dependent surface mesh as shown in Figure 1. However, when I create my Delauney volume mesh over this, the volume mesh forms incorrectly and goes outside the domain. I made sure that when the fluid-material point is being created, it is outside the blade and inside the domain. I have attached Figure 2 to indicate the wrong volume mesh. I have also made sure to delete the common surface that was present between the blade and the symmetry surface of the domain. Could anybody please tell me how I can go about to correct this. Thank you! |
July 26, 2015, 19:53 |
Rohith Giridhar
Rep Power: 11 |
I got my volume mesh correctly. I had not done build topology correctly earlier.
delauney volume mesh, unstructured mesh, wrong volume mesh |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
