[GAMBIT] Negative Volume
Like Tree9Likes
Old   August 21, 2015, 09:14
Default Negative Volume
Aja
aja1345 is on a distinguished road
Hi dear friends
I have a question about Gambit as follow:
I am meshing a turbine.
Please see the following dbs file of Gambit:
http://www.4shared.com/rar/C-pAhwRlba/max.html
I have used boundary layer mesh on the walls. But The mesh is not created in volume 10. In other words, the negative volume is created. Why?
I am grateful that guide me.
Thanks,
Best,
Aja
aja1345 is offline   Reply With Quote
Old   August 25, 2015, 02:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
no problem to mesh your volume 10 from my side
aja1345 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 25, 2015, 02:59
Aja
Yes max,
I change default of Gambit as follow:
Edit>default>mesh>volume>Use_3D_boundary_layers
I changed it to 0 and the volume 10 is meshed.
But with change, BL is not created well on the edge. 36 .Please see the following figure. How to solve it?
I am grateful that guide me about these subjects.
Thanks,
Best,
Aja
Old   August 25, 2015, 03:07
Aja
of course, My mean is the following file in this thread:
http://www.4shared.com/zip/RpSi4fHhce/max.html
Thanks,
Old   August 25, 2015, 03:42
-mAx-'s Avatar
Maxime Perelli
try to split surface in those areas for perturbing the topoloy. And recreate the BL.
You have lots of BL which are not on walls, why are you doing that?
Look also at the vertex.176 you have 2 BL which meet the good BL (surrounding your foil)
The same at vertex.174
aja1345 likes this.
Old   August 25, 2015, 04:22
Aja
what is your exact meaning of 'perturbing'? Which areas? I am grateful that guide me more.
In case of vertex 176: Which files do you explain? dbs file of this thread is different.
I had linked neighboring surfaces of the turbine for imposing periodic boundary conditions in the tangential direction.
In fact, periodical boundary conditions are imposed on the
neighboring surfaces of the turbine. I had to create lots of BL until Skewness is not appeared in these surfaces.
But now, I am using two interface and again in fluent, I do the following works as follow:
Define> grid interface>...
So I dont need to link these surfaces.
totally, I have to create BL in some part, Is there any problem?
Thanks,
Old   August 25, 2015, 04:48
-mAx-'s Avatar
Maxime Perelli
sorry
disturbing
in areas where you think the BL isn't proper.
Sometime if your surface is quite long , there could be problem.
If you split your long surface into smaller surfaces, it could help
Old   August 25, 2015, 05:15
Aja
sorry
disturbing
Ok, you are right,
But in edge 36 of face 113(please see #4), the face 113 is not long surface. Do you say that I also split this face?
According to your explanation, Should I create the new volumes?or just creating the new faces is enough?
Old   August 25, 2015, 08:25
-mAx-'s Avatar
Maxime Perelli
edge36 doesn't belong to surface 113
aja1345 likes this.
Old   August 25, 2015, 08:59
Aja
How do you understand that edge36 doesn't belong to surface 113?
But when I click on the edge 36, I think that this edge belong to surface 113!
Max, In this thread, I am saying about file of post 4 not a file is sent in private massage for you.
I am grateful that guide me more about these subjects.
thanks,
Old   August 26, 2015, 01:11
-mAx-'s Avatar
Maxime Perelli
Command> face summarize "face.113"
Face: face.113
Scheme: Map
Interval Size: 1.000000
Interval Count: 10
Meshed: Yes
Total mesh nodes: 4331
Total mesh faces: 4200
Total Edges: 4
Name Meshed: Vertex_1 Type Vertex_2 Type
edge.248 Yes vertex.269 END vertex.267 END
edge.260 Yes vertex.275 END vertex.269 END
edge.259 Yes vertex.275 END vertex.274 END
edge.257 Yes vertex.267 END vertex.274 END
Face used by the following 2 volume(s):
volume.19
volume.27
Centroid: ( 0.002559, 0.486907, -0.246806) Coord Sys: c_sys.1
Bounding Box Min: ( -0.057487, 0.486907, -0.298750) Coord Sys: c_sys.1
Bounding Box Max: ( 0.062500, 0.486907, -0.189984) Coord Sys: c_sys.1
Area: 0.011972
aja1345 likes this.
Old   August 26, 2015, 02:31
Aja
Hi max,
I removed some BL according to your explanation. But again negative volume is created(in volume 44). I am grateful that see the following file:
http://www.4shared.com/zip/N7-j56_xb...ormance-N.html
I am grateful that guide me more about this problem. why the negative volume is created in this case?
I performed many attempts in order to create real volume but is not created!
What do I do?
Face: face.113
Scheme: Map
Interval Count: 10
Meshed: Yes
Total Edges: 4
volume.19
volume.27
Area: 0.011972
Your explanation is not about dbs file of this thread.
Thanks,
Best,
Old   August 26, 2015, 03:05
-mAx-'s Avatar
Maxime Perelli
check the picture
aja1345 likes this.
Old   August 26, 2015, 03:25
Aja
check the picture
Attachment 41645
Hi max,
Thanks your answer.
I had performed this work and The negative volume is created in volume 10 in the following work. please see the following dbs file, Perhaps I am wrong.
http://www.4shared.com/zip/GVe275Aiba/max.html
even those splits should be normal to the body?
Old   August 26, 2015, 03:34
-mAx-'s Avatar
Maxime Perelli
keep only the BL around your body (and use suface not edge)
aja1345 likes this.
Old   August 26, 2015, 03:50
Aja
I perform your explanations, If again I had the problem, I post here.
Thanks
Old   August 26, 2015, 05:15
Aja
I constructed a new model and performed your explanation, But again the negative volume is created. please check the following dbs file:
http://www.4shared.com/zip/Bngok1a8c...mance-New.html
Really I don't know what to do until this problem is solved.
Thanks,
Old   August 26, 2015, 05:31
-mAx-'s Avatar
Maxime Perelli
check if you problem comes really from your BL and not from your topology.
For that delete your BL, delete your volume mesh, and remesh (without BL)
aja1345 likes this.
Old   August 26, 2015, 05:41
Aja
really thanks,
This work performed(without BL), But again the negative volume is created!
What is your exact meaning of "topology"?
Old   August 26, 2015, 05:43
-mAx-'s Avatar
Maxime Perelli
post a screenshot of your mesh
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 05:06
[ICEM] negative sector volume adam2008 ANSYS Meshing & Geometry 0 August 9, 2014 00:24
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
remeshing due to negative volume error Doginal CFX 1 August 21, 2011 21:50
