[ANSYS Meshing] Non-conformal mesh regions are not communicating between each other
Old   September 8, 2015, 06:08
VINAY PRASAD
vinay5150 is on a distinguished road
I have one body which I have divided ino 5 parts using slicing operation. And I have not formed multi body part since I want non conformal mesh. I have created mesh interface and also contact sizing in the contact between two non conformally meshed part of fluid domain yet it seams by seeing result, every part is working independently and there is no connection between parts. How to solve this issue???
Last edited by wyldckat; September 8, 2015 at 15:48. Reason: merged posts that were a couple of hours apart
vinay5150 is offline   Reply With Quote
Old   September 8, 2015, 08:28
Antanas is on a distinguished road
There's no telepathist here. Need more info. What do you mean by "created mesh interface and also contact sizing" abd "every part is working independently"? What solver do you use? Post some pics.
Antanas is offline   Reply With Quote
Old   September 8, 2015, 10:24
VINAY PRASAD
sorry. I am using ansys fluent. I am unable to post pic here. If possible give me your email id so that I can send it to you.
Old   September 8, 2015, 11:57
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
This is the outcome of the input
So if you need the non conformal mesh, you need to create interfaces.
Far is offline   Reply With Quote
Old   September 8, 2015, 12:00
VINAY PRASAD
yes thats why I created interfaces but then also flow is not transferred from one part to another...What can be the reason??
Old   September 9, 2015, 01:56
hwet is on a distinguished road
Select all the different parts in design modeler and make a single body from them. At the moment you have a number of bodies each of which is a different part. It should all be one body with different parts.
This has been addressed before multiple times in the forum.
hwet is offline   Reply With Quote
Old   September 9, 2015, 02:37
The reason may be interface setup.
Old   September 9, 2015, 04:37
VINAY PRASAD
yes, I know what you are talking about. But IF I am forming multibody part , then mesh is forced to be conformal which result in unstructured mesh. Thats why I am keeping it multi part to let it be non-conformal aand by this way I am able to get structured mesh in every part. But the problem is now the connection between the parts.
Old   September 9, 2015, 04:42
VINAY PRASAD
May be you are right but let me explain you how I am setting the interface. Suppose I have a body. I sliced it in the middle. Then now I have 2 part and 2 bodies. Now I have one interface. I created named section for two faces forming that interface(by hiding one part so that I can name the face involved in the interface) . Now i used mesh interface option to create interface. Whats wrong in this???
Old   September 9, 2015, 06:50
Citation from Fluent Training Meterials:
If the nodes do not match up, this is a ‘Non Conformal’ mesh
– Fluent can interpolate across the interface, but this must be defined in the GUI.
– If not, Fluent will treat the interface as a wall, and no fluid can flow through.
So open interface options and set up.
Old   September 9, 2015, 13:28
Joe
enayath is on a distinguished road
Hello Folks,
My problem is kinda similar but not the same...I have 1 fluid domain with 2500 bodies and 1 solid domain which is in the fluid domain with 900 bodies. I want to make 1 part 2 bodies in order to have conformal mesh and wall shadows in Fluent. I set the shared topology of Solid domain and Fluid domain each separately to automatic and then make them in one new part.( so in design modeler i have 1 part two bodies) ...when I go to meshing and look for just solid domain, it does not show all bodies of solid domain and so many bodies are missing. any idea how to fix it? The photos of my case are available on this link.
Thanks a lot!
enayath is offline   Reply With Quote
Old   September 10, 2015, 12:17
Originally Posted by enayath View Post
Hello Folks,
Thanks a lot!
There're 2 parts and bunch of bodies on your images but not 1 part and 2 bodies. Show actual pics with outline tree from DM and AM.
Old   September 15, 2015, 09:36
Default Geometry vanished in Meshing!
  #13
Joe
Hello Guys!
I have a problem. In DM, I have 1 solid domain with 1 body and 1 Fluid domain with more than 2900 bodies. I set the shared topography to automatic for all bodies and make these two domains in 1 part. When I open the geometry in Meshing, The solid domain does not show properly(most of the solid parts are not shown). Any idea would be appreciated!
I attached the pics.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
