[ICEM] how to force hexa mesh to stick to surface (i.e. make edge nodes follow surface)? |
October 16, 2015, 15:04 |
David
Rep Power: 10 |
Hi everyone,
I am having troubles fixing my hexa mesh to stick to the symmetry plane surface (see pictures). The problem arises when I replace the circular backwardfacing step geometry with a slope and it results in this hole in the mesh on both sides. Any suggestions on how to fix this? Is it a blocking problem? Or will I have to try to set up a hybrid mesh with a tetra part for the slope? Unfortunately I couldn't find any help in tutorials or other threads. I also checked that the blocks are well associated at these edges. Any help is much appreciated! I can also provide files when needed. Thank you, Dave Last edited by dave13; October 21, 2015 at 11:17. |
October 19, 2015, 05:28 |
#2 | |
Rep Power: 18 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
To make sure nodes on surface | Twiti | CFX | 0 | December 23, 2004 20:06 |
