[ICEM] Interface Problem / Resolution of ICEM
Like Tree2Likes
  • 2 Post By Bembei
Old   October 22, 2015, 11:40
Default Interface Problem / Resolution of ICEM
Michael Stemplinger
Bembei is on a distinguished road
i got a problem with the interface between the distributor and the runner of a Francis-Turbine. "Fluent" says that the interface overlap but the diameter of distributor-outlet and runner-inlet are the same. This looks like an resolution problem in ICEM. Here some pictures.
problem.jpg problem_surface.jpg assembly.PNG resolution_1.JPG resolution_2.JPG
Why is there this burr on the edge and why is the mesh-surface piecewise linear.
Is there any chance to solve this problem, to improve the circularity? By the way this is for my bachelor's thesis and the geometrie and blockings are given.
I appreciate your help,
Best,
Michael
Bembei is offline   Reply With Quote
Old   October 23, 2015, 10:03
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
which type of interface you are using. Keep in mind you need to select different settings for axial and radial machines... !!!
Far is offline   Reply With Quote
Old   October 26, 2015, 04:45
Michael Stemplinger
Thanks for the response Far,
I have chosen these settings for the interface:
The preview mesh motion works and gives the following resultes:
I'm using the "Mesh Motion" methode.
Is this the right setup for the interface?
Thank you in advance
Old   October 26, 2015, 05:47
Far
Sijal
choose only periodic repeats as I am assuming you want to have stator-rotor interface. Un select any thing else.
You mean to say "for sliding mesh" ?
Old   October 26, 2015, 10:07
Michael Stemplinger
yes i want to have stator-rotor interface:
Interface.JPG : Interface is yellow.
I have chosen the following setting for the interface
I did not choose the periodic repeat because I don't have a periodic geometrie. I have made a calculetion and it worked, thanks! But Fluent reports "Info: Interface zones overlap for mesh interface interface-sc-runner. This could adversely affect your solution." It's only an info, can i gnore it?
Old   October 27, 2015, 03:07
Far
Sijal
Ok. Since you are modeling complete (360) geometry, therefore you dont need to select the periodic repeats.
I cannot recall exactly where this command is located, but there is different option to be selected to radial and axial machines in interface.
Old   November 3, 2015, 07:28
Michael Stemplinger
I found the solution. ICEM has a limited resolution of surfaces and curves thats made my interface non‐axisymmetric. The problem was fixed by creating an interface surface and curves over only 1 degrees, and copying those to the full
360 degrees giving a much better representation.
Thanks Far for your help.
Far and Maerluz like this.
interface mesh, overlapping interfaces, picewise linear, resulution
[Commercial meshers] Problem with cyclic boundaries in Openfoam 2.3, mesh import from ICEM Scabbard OpenFOAM Meshing & Mesh Conversion 29 October 6, 2020 21:14
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
[ICEM] ADINA interface problem Daniel_Khazaei ANSYS Meshing & Geometry 3 May 5, 2014 06:58
interFoam - stratified flow - problem with shear stress at interface AnjaMiehe OpenFOAM Running, Solving & CFD 8 June 14, 2010 06:49
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
