[Workbench] import geo. and mesh from ICEM to workbench
Like Tree1Likes
  • 1 Post By PSYMN
Old   December 11, 2014, 12:04
Default import geo. and mesh from ICEM to workbench
Abdulaziz Abutunis
ama294 is on a distinguished road
Hi Everyone,
Please, is there a way to import the geometry and the mesh from ICEM to Workbench. Sorry I am quite new with workbench.
thank you
Aziz
ama294 is offline   Reply With Quote
Old   December 12, 2014, 09:33
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yup, assuming you have version 15.0 or newer, check out the component system called "External Model". This system lets you attach meshes of various formats and then you can connect a mechanical system... You would have to write the mesh out of ICEM CFD in one of the formats that it accepts.
You could also trick it with "ICEM CFD interactive" within ANSYS Meshing, you just need to go into ICEM CFD interactive and then load your mesh. It is a bit more complicated because your mesh topology (including part names, etc.) must match the geometry in ICEM CFD interactive or it won't be able to reconnect the two when it sucks it back into ANSYS Meshing..
ama294 likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   December 12, 2014, 12:31
Abdulaziz Abutunis
Thank you Simon.
Old   March 3, 2016, 03:02
bitpeng is on a distinguished road
I employed this method to generate mesh, but when I done the mesh and come back to ANSYS Meshing, the mesh generation was not successful and the error as:
"MultiZone could not generate a valid mesh."
Do you have ideas about this? Could you tell me how to do this successful?
Thank you very much!
bitpeng is offline   Reply With Quote
icem to workbench
[ANSYS Meshing] Import Mesh from CFX-Solve to OpenFOAM A.Stamatopol ANSYS Meshing & Geometry 1 July 25, 2013 11:08
[Gmsh] wing mesh with gmsh huitetquatre OpenFOAM Meshing & Mesh Conversion 0 January 26, 2013 03:16
CFX4 mesh from ICEM HEXA David CFX 2 June 27, 2005 18:35
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
