January 28, 2016, 05:12 |
Can't generate volume mesh
NhanLe
Rep Power: 10 |
Hi guys, I am pretty new to ICEM and trying to mesh the hydro turbine. The plan was generating the volume mesh from the surface mesh. I used All Tri for the surface mesh and Tetra/mixed (Delauney) for the volume, but the volume mesh was quite weird. I have defined the body too. Anyone can help ??? Thanks Capture.jpg
Capture1.PNG |
January 28, 2016, 09:58 |
Maxim
Rep Power: 12 |
looks like your associations are incorrect.
I would suggest you work your way through all the tutorials and start with easier geometries before you work with such a complex geometry. A blade itself is a challenge to mesh. In your case, a pattern would also be useful. Mesh one blade with the area around it and then copy that for the other blades (assuming that they are all the same...). |
November 12, 2018, 01:54 |
NhanLe
Rep Power: 10 |
Thanks very much for your advice.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
