February 6, 2016, 14:46 |
3d meshing problem
Mahmoud
Rep Power: 11 |
hi every one
i wanna convert a 2d compressor blade mesh to 3d one [IMG][/IMG] according to this tutorial https://www.youtube.com/watch?v=l-Tz6MHlT1M i did all tutorial's steps but a problem appeared that some mesh came together at the same point and vertices like a photo attached [IMG][/IMG] i wanna fix this problem thanks advanced to all |
February 10, 2016, 19:05 |
Rep Power: 13 |
Check the blocking you will be able to see where the problem is arising. you will probably have to do the association of lines to curves again in this region.
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
