ICEM CFD Unstructed Mesh Curvature Function
Old   February 9, 2016, 04:58
Default ICEM CFD Unstructed Mesh Curvature Function
Drum.7 is on a distinguished road
Hi there,
I am trying to build a 3D unstructed Mesh with ICEM CFD and use the Curvature Function. In general it works how it should, but at some places it projects the small cells from the bottom side to the upper side (see attached files). I tried to fix it, by changing tolerance parameters, but I am not quite sure if this is the right way or if i did it the right way. Does anyone has an idea?
Thanks for your help!
Drum.7 is offline   Reply With Quote
[ICEM] The ICEM Guide for CFX Users JuPa ANSYS Meshing & Geometry 11 September 4, 2017 09:43
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
