[TurboGrid] shroud tip problem
Old   February 20, 2016, 01:45
Default shroud tip problem
Alex
Red Ember is on a distinguished road
Curious problem
I use variable normal distance option to model shroud tip.
Values are as following:
2.2mm at leading edge, 2.7mm at trailing edge.
TG successfully creates topology with 2.55 and 2.7mm respectively but it's somewhat threshold! Trying to change 2.55 to 2.2 I get an error:
Curves do not intersect for creating TurboTransform.
How can I fix it? Why 2.5mm is the critical value? Where can I adjust it?
Red Ember is offline   Reply With Quote
Old   February 20, 2016, 01:52
Alex
I can't even use mean value 2.45mm
But constant span option (span about 0.97 and more) works fairly well.
Too bad there is no variable span option...
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 21:10
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
