March 20, 2016, 05:09 |
mesh not showing
kasra
Rep Power: 10 |
hello
im trying to mesh a geometry using Mutizone method. so when I try to generate the 2D surface mesh using ICEM CFD and I check the premesh option after the recomputing finishes still it does not show the mesh. now I don't know whats going on here as im new to ICEM and would appreciate any help. thanks in advance |
October 19, 2017, 01:02 |
Andrew Fung
I am facing the same problem as well. I have followed the instructions in the multizone tutorial. Build diagnostic topology (all curves in red) > set global mesh size > part mesh setup > auto surface blocking. But the pre-mesh would not appear.
I have succeeded on a simpler geometry before so perhaps it is due to the complexity of my geometry. It is the fluid region around a propeller blade and its shaft. Any help would be appreciated, thanks! |
May 20, 2019, 05:11 |
Rep Power: 8 |
Hello ICEM people,
same here. I recomputed the premesh like I did already about 1,000 times in my ICEM project (and it worked the 1,000 times, I could see my premesh). The only difference now is that my total number of elements is much higher (Right-Click on Pre-Mesh (green arrow is there, but premesh is not showing), Pre-mesh info ->about 50,000,000 Quads, in 2D). So maybe it depends upon the amount of data generated. Maybe a software problem (ICEM CFD 19.2)? Thank you in advance! |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
