[GAMBIT] how to do an opening ventilation in a garage |
May 3, 2016, 13:30 |
Moetez Bel Arbi
Rep Power: 10 |
I have to draw a garage with two opening ventilation , ( circle and a rectangle)
but I can't do them. Plz help me how I can do ?? |
May 4, 2016, 01:08 |
Maxime Perelli
Rep Power: 41 |
explain what you did
In memory of my friend Hervé: CFD engineer & freerider |
May 4, 2016, 19:29 |
Moetez Bel Arbi
Rep Power: 10 |
I have to build a garage with 2 opening ventilation. but when I creat the volume of the garage then I draw the faces of the openings , and mention them like a oulet_vent , in fleunt didn't read it , ( skipping zone not referenced by grid)
May 9, 2016, 01:17 |
Maxime Perelli
Rep Power: 41 |
that means you applied the bc on a surface which doesn t belong to the mesh.
This is a typical connectivity problem In your case you don't have to draw the faces of the openings, but you have to split a face of your volume for having the desing of your opening. Try to split the surface of your volume (where your skteched the face of opening) with this face of opening. You it is still unsuccessfull, please display any picture in area of the openings
May 9, 2016, 06:45 |
Moetez Bel Arbi
Rep Power: 10 |
Thank you so much Max , it works now , and fluent can read the faces of openings , I hope that will give me good results ,
Thank you again |
"Hand" calculation jet fan in the garage | mageno | Main CFD Forum | 3 | August 7, 2021 19:09 |
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 18:00 |
How does CFX treat an opening when heat transfer is modelled? | JuPa | CFX | 2 | September 9, 2014 05:34 |
How to properly set up an opening in buoyancy driven problems | lavoz | CFX | 5 | July 23, 2014 06:06 |
forced ventilation boundary conditions???? | annu | Main CFD Forum | 0 | May 2, 2014 09:05 |
