May 22, 2016, 10:52 |
Geometry and Mesh from STL file
I'm working with an STL file of a blood vessel, I need to modify the geometry and build a robust mesh. The imported geometry is very irregular and I managed to trim out most of the little vessels attached to the main one. After these (probably badly performed) operations the build topology tool can't seem to fix much and the geometry I'm left with is full of errors, holes and imperfections. 1)Is there a way to smooth out my geometry so it can be meshed better? 2)If I import the STL file as mesh the inlet and outlet surfaces are badly meshed; how can I modify the mesh on just a selected surface? Thank you to whomever will reply! |
May 23, 2016, 03:41 |
Paurnamie Samarakone
Rep Power: 10 |
Hi
I had a problem like you. However my geometry is axisymetric and quite simple. So I did a "surface-surface intersection" with my geometry and a surface I created and "redraw" the geometry... I first drew an axis which luckily for me goes straight through my geometry. Then I drew a surface. DO you see what I mean ? Hope this helps. Good luck ! |
May 25, 2016, 06:22 |
I appreciate your advice. I ended up solving the problem by not using ICEM to trim out the parts I needed to remove, instead I used Paraview which is a freeware and it's much easier to use. I then used Meshlab to fill the holes in a matter of minutes and then exported the stl to ICEM to mesh it. Such mesh appears to be working alright and can be imported into Fluent without problems. |
May 26, 2016, 08:28 |
Rep Power: 10 |
Nicely done !
Btw, I just learned that working on STL fils on ICEM is not a good idea. It's easier if you have b-curves, b-splines, etc. ICEM works better on those than STL format ^^ Good luck ! |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 04:12 |
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh | Irish09 | OpenFOAM Meshing & Mesh Conversion | 9 | April 7, 2012 08:50 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] Mesh a geometry without stl file | eysteinn | OpenFOAM Meshing & Mesh Conversion | 0 | May 5, 2011 10:15 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
